A few Lt1 trans questions
Old 05-06-2008, 02:49 PM
slowec's Avatar
Default A few Lt1 trans questions
Did a 93 Z28 come with a 700r4? Will the same stall fit a 93,94,and 95. I am not a lt1 guy but I ended up with a stall and I am tryin to get answers for my potential buyers.
Thanks in advance for any help!!!
Old 05-06-2008, 03:37 PM
LS1Tech Sponsor
performabuilt's Avatar
The 93 had a 700r4 some call it a 4l60 because it had a different harness plug but it was still a hydraulically controlled trans, As for the converter if after market stall should fit 700r4 and 4l60e from 86 to 97 , If a stock converter can only be used to 94 as after that the lockup strategy became PWM and requires a different lockup clutch material.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-06-2008, 06:41 PM
slowec's Avatar
Default Thanks
