a4 trans problem,,WTF??
Old 05-06-2008, 08:39 PM
kclskgl's Avatar
Default a4 trans problem,,WTF??
Ok,i can drive at 65-70 but as soon as i slam it to the floor it goes to 80mph and 6000rpm and doesn't shift,sounds like i'm hitting the rev limiter but if i let off and feather it gentle it goes over 100mph no prob. This happened before i blew my trans, i spent $2500, for a complete over haul and it does it with the new one? I dont know whats up. With the new trans it did it after a burnout,but just a small one,is it getting hot?
Old 05-06-2008, 08:53 PM
LS1Tech Sponsor
performabuilt's Avatar
Have you tried kicking it down in the D position does it do the same.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-06-2008, 08:57 PM
kclskgl's Avatar
I havent tried that but next time i will, but i know it was in od.
Old 05-06-2008, 09:04 PM
LS1Tech Sponsor
Reason I ask the overun clutch is on in D and will support the sprag , If the sprag was not replaced in the rebuild then it may be letting go on hard acceleration
__________________
Call 888-744-6542
Old 05-07-2008, 05:24 PM
kclskgl's Avatar
They said the replaced it with a hardend sprag,but i would have rather got the one from you. I was the one who called looking for a trans in pa when i broke down.
