A4 guys take a look at this shifter
I don't see what the big deal is. If the guy was parting the car out it's easier to just cut them. If he knew you needed it for a M6 to A4 swap I'd say he was being generous to give you all the plug ends in case you needed them.
Yes I do believe you will be fine with the A4 engine harness. I believe that harness also has the transmission wires in it and all you should have to do is find the connectors on your harness and plug them into the shifter.If I am wrong about this then the seller still did you a favor by giving you the connectors since you will have to still wire all that stuff into the computer.
Changing the interior wiring is a pain.
If you do the two things above you'll get the basic stuff. You still won't have the rear hatch interlock, and brake pedal lockout.
Did you plan on running the cable from the shifter to the steering column?
I meant to say are you going to make the brake pedal lockout functional?
It's that solenoid that requires you to have your foot on the brake before the shifter will come out of park. That could be a problem finding the wiring for that. Unless you get an A4 interior harness.
He cut them so you can hook up the switches on the shifter. I just got done with doing this on my m6 - a4 swap. Here is were i found out how to kook everything up.
https://ls1tech.com/forums/automatic-transmission/200477-m6-a4-a4-m6-conversion-info.html
Post #16 to get everything to work with the shifter.
If you need any more help pm me since i just did this less then a week or go.
