Lockup Clutch Going?
Old 05-14-2008, 09:34 PM
articz28's Avatar
Default Lockup Clutch Going?
When driving normal it locks up fine but after a full throttle blast it takes it like 3 min to lockup again. temps stay around 150. Also when going up a hill it feels like it surges alittle like it is slipping. Any input would be helpful. I would like to catch it before it goes so it don't take my built tranny with it. Ohh by the way this is the infamous TCI SSF 3500.
Thanks.
Craig
Old 05-14-2008, 09:36 PM
LS1Tech Sponsor
performabuilt's Avatar
You would need to data log to see whats happening for sure but I would look at fluid and face of converter for burning also.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-14-2008, 09:43 PM
articz28's Avatar
Fluid looks fine but when I run it through my fingers it does leave some dark film like a super fine grit. that you can't feel.
But I can drop the flywheel cover and see if converter looks burnt???
Old 05-14-2008, 09:48 PM
LS1Tech Sponsor
Yes in the flat area on the converter face
__________________
Call 888-744-6542
Old 05-14-2008, 09:52 PM
articz28's Avatar
Ok. I will try and get to it this weekend if it ever stops raining here. Thanks for the help and I will report back with the results.
