shifter cable/linkage not lining up on 4l80e
I'm using a stock A4 shifter with my 4l80e and the cable is longer then the linkage. I'm using the linkage from a 4l60e. Do I need the longer linkage for a 4l80e or is there an adjustment on the cable?
Mines not perfect but works. I had to modify bracket as did 30th ta, get a small circular rough file and elongate the wholes will they both line up with tranny pan bolts.
http://i173.photobucket.com/albums/w...m/DSC02711.jpg
http://i173.photobucket.com/albums/w...m/DSC02709.jpg
Stud stayed on there from 4l80e.
Used 4l60e shift linkage.
Bringing this back from the dead... I was thinking I could use my 4L60 linkage and mount bracket but I just cant get it to line up right... those that have used it were you able to just bolt it up? Ill take some pics tomorrow after work. For those that have used the 4L60 linkage and bracket... can you share some pics?
Thanks.
Thanks.
