3/4 clutch
LS1Tech Sponsor
No I spoke to you earlier today, The shift kit does not bypass clutch packs it only replaces the PCM for control If the 3/4 pack has failed you will need to replace it or more likley rebuild or replace the transmission. Either procedure involves tearing down the transmission
__________________
