Proper way to check transmission fluid?
I would like to know the correct way to check transmission fluid, i know this probably sounds like a stupid question, but over the years i've overheard and been told different ways, and i just want to know the correct way. thanks
Yes, you should go through the gears pausing in each, then check in park engine running at idle for 3 minutes more. You can also do a "static" check if it's been sitting for at least 8 hours, but only as a reference. Procedure is in the owners manual and also tells you when not to check it also, like in hot weather right after sustained highway driving, etc.
