no 3rd or OD 95 Z28
no 3rd or OD 95 Z28
I have a 95 Z28 with the 4l60e and I recently lost 3rd and 4th gear accelerating normal from a stop. Whats weird is the transmission does not try to shift at all just acts as it's in neutral until you reach the 2nd gear RPM you would be traveling at in 2nd and goes back into 2nd. Now the even weirder thing is I will randomly get 3rd and 4th back after a couple weeks of driving in 2nd (I have no other way of getting to work). Would this be a stuck solenoid? I'm having bad luck this month with Transmissions lol first my 98 and now my 95 is acting up!
Bringing my old thread back to life! I finally got around to changing both shift solenoids and I'm still getting no shift. I unplugged the trans from the PCM and it wouldn't default to 3rd. What does this mean? Could there be a problem with the valve body? 1 thing I did notice was a pin was spring loaded on solenoid A but no pin came out of solenoid B?
Ok, Well I figured it was shift solenoids because it randomly went into 3rd/4th while I was driving once and it was shifting great until I shut the car off and parked it for 5 min So it sounds like the pin is getting stuck. What needs to be done to fix that? New VB? The trans has new clutch packs in it and a new pump.
Alright, I finally got around to cleaning the valve and still nothing. This is very aggravating. Probaly out of luck by now but anymore ideas? I really appreciate all the help and I will be definitely buying a Performance trans for my 98 off a sponsor soon!
