New Tranny Problem
Old 06-09-2008, 10:35 AM
dpinson's Avatar
Default New Tranny Problem
got a new tranny installed and it shifts fine except under wide open throttle
it kinda seems like the rpms get stuck and quit rising at about 5000-5500rpm and the tranny wont shift, any ideas
Old 06-09-2008, 10:39 AM
big wally 55's Avatar
Get it to a tuner , probably bumping the rev limiter !
Old 06-09-2008, 10:58 AM
LS1Tech Sponsor
performabuilt's Avatar
Yes sounds like your hitting rev limiter likely need some tuning and you will be good.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-09-2008, 04:12 PM
chevyz2801's Avatar
Something like that was happening to me got my car tuned and that fixed it. When you let off the gas it shifts right
Old 06-12-2008, 11:09 AM
dpinson's Avatar
UPDATE,when you floor it it hangs at about 5000 rpm almost like it isnt getting enough fuel to the motor,if you back out of the throttle a little the rpm's will climb a little more and then make the shift
does that still sound like a tune issue
Old 06-12-2008, 11:22 AM
LS1Tech Sponsor
It sounds like either the shift is commanded to close to the limiter or theres some engine running issue , I would think the limiter would be higher than 5000 rpm though. I think its more likely your dealing with and engine running issue or a tuning issue , But it just hanging at 5000 sounds like the engine is for whatever reason not reaching the RPM needed to make the shift at WOT. Possible restricted fuel filter maybe?
And did you install a different stall speed converter from previous and if so have you had the car tuned for it?
__________________
Call 888-744-6542
