who can definitively tell me what it takes to use a 94/95 trans in a 96+
Old 06-11-2008, 12:29 AM
84TATURBO408LQ9's Avatar
Default who can definitively tell me what it takes to use a 94/95 trans in a 96+
ive heard all sorts of different info,and its pissing me off,ive googled this to death,with no real results.
my trans finally decided to completely grenade itself,this was 750 miles after it lost 2nd and OD.
now since i lost 2nd and OD,ive been searching for a 96/97 transmission,with little to no luck,yet i find TONS of 94-95 trannys.
ive been told the following,any 94-97 trans will bolt right in and function perfect
i can only use 96/97 only
i can use a 95 trans,but the vss and housing,and the 3-2 shift solenoid need to be switched from a 96+ trans.
i CANT use a 94 trans..
who here on this board,can without a single doubt,tell me what the actual truth is? i need a trans,and i need one as of like yesterday.
Old 06-11-2008, 01:13 AM
LS1Tech Sponsor
performabuilt's Avatar
email me at performabuilt@yahoo.com I will explain but yes you can do it
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-11-2008, 07:27 AM
lt170chevelle's Avatar
i did a 95 to a 94 swap and had to swap the valvebodies , my 94 on to the 95. i thought the 95 and ups were the same but i am probally wrong.performabuilt walked me through the swap last year.
Old 06-11-2008, 10:43 AM
performabuilt,i emailed you about the trans conversion,havent gotten a reply back yet.
you can just post here if you want to for future members needing the same info?
Old 06-11-2008, 11:29 AM
LS1Tech Sponsor
Yes just haven't had the chance to reply yet its a little detailed, Have had a busy morning but will shortly .
Thanks
__________________
Call 888-744-6542
Old 06-11-2008, 08:32 PM
Thanks
ight well,when you get the chance my emails iroc88lb9@yahoo.com
Old 06-11-2008, 08:36 PM
LS1Tech Sponsor
Email Sent
__________________
Call 888-744-6542
