HELP!!!! FINDING GRADE 8 Metric Bolts for Torque converter Whats Strongest in metric?
Where can i find a M10 x 1.5mm x 20 mm long bolts at for my Torque converter ? i cannot find a Grade 8 for nothing , im beginning to thing Grade 8 and 5 bolts are just for a standard Bolt not metric , the only thing i have seen for metric is an 10.9 or an 8.8 , but cannot find a Grade 8 bolt , HELP ME OUT HERE ASAP thanks
whats the strongest bolt in metric ? im lost as far as what kinda of Grade bolt to find in metric since there are no Grade 8's
ok cause everyone confusing me saying that i need a grade 8 metric bolt and im was thinking that i dont know of one .. what size you think is best ? 20mm long or 25mm long ?
That I don't know.
If the back side of the bolt hole is open, it won't hurt if the bolt is a little long. But if it's a blind hole, then you have to be pretty close on the size.
The TCI flexplate definitely takes a longer bolt than stock.
Also if you have to space the converter by using a washer, you'll need a little more bolt length too. You probably won't have to space it, but it would be good to know for sure.
ones that came with my yank are too short...i bought the next size longer locally....i have tci plate as well. Also, i needed to find some bolts with the rounded hex head like yank sent...regular bolts/heads hit the bolts on my rear engine cover with the tci plate. I got 6 bolts locally for 2 bux....ACE hardware prolly has em.
Factory bolts are usualy 9.8, so that should be the minimum. I would suggest the 10.9 if you can find them. I have used www.theboltdepot.com sometimes. Fast shipping and huge selection. But local is obviously much faster. As far as length, the longest possible is preferred. but do not bottom it out - causes big problems. You need the flywheel and converter to measure properly. The OEM flywheel is about 0.100" or 2.5 MM. I don't have a TCI to measure right now but I would guess about 0.350" or 9 MM. They have about a 0.250" spacer welded to the plate.
Hope this helps a little.
Chris
Chris
