help quick a4 ls1 tranny stuck
Old 06-13-2008, 09:24 PM
1badchicken's Avatar
Default help quick a4 ls1 tranny stuck
ok so me and my dad are trying to take out the tranny. all bolts are off but stuck just as it wants to come off. does the torque converter come with the tranny? are we missing something?
Old 06-13-2008, 09:28 PM
LS1Tech Sponsor
performabuilt's Avatar
yes the converter doescome off with the trans and you must have it unbolted from the flex plate , After you have that spray some PB BLASTER on the dowel pins and if your sure all the bolts are out including the one dead center top shake it like crazy but be ready to get out of the way be carefull
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-13-2008, 09:37 PM
Default help
how do i get the three bolts out they look like hex bolts not your standard type does the starter have to be off?
Old 06-13-2008, 10:07 PM
LS1Tech Sponsor
removing starter some say is easier but the bolts are called torx bit and if you dot have a torx bit set go get one and a good one not a cheap set, Go to sears some hwere like that
__________________
Call 888-744-6542
