4l80 t-brake users what filter!!?
i got the brake back from being worked by rossler and thought i would put in a fresh filter. i bought one from autozone ad threw away the old one
the one i got says TF304 T709. IT does not work! it hits the bottom of the moroso pan.
i havent read anywhere about a special filter, but now i'm stuck.
the tf304 has a shorter neck but a thicker body opposed to the one i took out having a longer neck and a thinner body (thin enough to fit between the brake and the pan.
thanks
thanks
You will need to get an early filter with the Moroso Pan. The late filter with the dimples on it does not fit(98 and later). You need the one that is completely flat. Try to get one for a 93-97 model year IIRC. Also make sure that the filter is in the proper location over the manifold switch/brake body. BTW that Moroso pan looks sweat!
What problems did you have with the brake? Vince
