got a B&M Tranni Cooler 19,000GVW Cooler where to INstall in 99 Fbody
Old 06-29-2008, 03:40 PM
BadLtBlu99TA's Avatar
Unhappy got a B&M Tranni Cooler 19,000GVW Cooler where to INstall in 99 Fbody
I have a B&M tranmission Cooler 19000 GVW where is a good place to INstall this tranmisssion Cooler ? im lost here , and what lines that goes into the OEM Tranni Cooler do i need to use , how to run the lines , i know it goes from Tranmission to the OEM cooler to external Cooler , then back to Transmission , but what line do i take off the OEM Tranni Cooler and RUn to the External cooler ?
Old 06-29-2008, 03:47 PM
bottlefed98's Avatar
I have the same cooler on mine mounted in front of the condenser. I bypassed my stock cooler in the radiator and went straight to the external cooler... some say go thru both,some say not to its really up to you.
Old 06-29-2008, 09:24 PM
does anyone have a picture of where they put there external tranmission cooler , i would like to check it out if anyone has a picture , thanks again
Old 07-01-2008, 12:41 PM
2002BLKWS6's Avatar
Hey man... try this thread. CLICK ME
There is a link in the thread to someones site that has pics of when they installed theirs. I used this link over 2yrs ago when i did mine, and it wasn't that bad. The link still works.
I have also heard of people installing them "Dope style"... do a search on that and you may get some add'l pics of other areas people are putting them. There is a couple of pics of that in this thread also.
Good Luck.
Old 07-02-2008, 10:22 AM
nahasapeemapetalon's Avatar
https://ls1tech.com/forums/showthrea...873&highlight=
Check out my post.
works great i havent surpassed 180 degrees yet
I have the B&M:70274 and mounting kit 80278
