Transmission slipping???
I have a '04 GTO A4 with a Predator tune. Yesterday on the 1-2 and 2-3 shift she started bouncing off the rev limiter so I had to back off so she could short shift.
When I took the predator tune out and put her back to stock she shifted fine in every gear. I put the Predator tune back in and she started bouncing off the limiter again!! Anybody experience this or know what the problem might be?? I've had the Predator for nearly a year now and haven't had any problems.
I'm not familiar with the mods that the tune is making.
Are you saying that you've run the same Predator tune for quite a while?
I trust you are experiencing problems only at WOT?
I would have to see the shift tables to better understand your issues. If you could find those and get them to me in a format I can use I would be happy to look into it for you.
I am not aware of any of our clients running the Predator tunes.
g
g
g
g
The rev limit was orginally at 6189 in each gear and they said that was too low and in the heat she'll want to go past that.
