3/4 Clutch pack question-adding extra steel
Old 07-15-2008, 01:23 PM
Rosco's Avatar
Question 3/4 Clutch pack question-adding extra steel
Hello all!
I am in the process of rebuilding my 4l60e, all has gone well so far.
I have just put in the high performance 3/4 clutches (6) and the clearance is huge, if I add an extra steel in the middle so its clutch/steel/clutch/steel/steel/clutch/etc it tightens up the clearance to about .062.
Will this be ok or should I be doing something else to sort out the clearance?
My previous clutches were burnt up pretty bad, gone black and have coned.
Old 07-15-2008, 01:33 PM
Gilbert@Ace Racing's Avatar
Well we prefer to see a clearance of something closer to .030 - .035... after it has a few hits on it! That means you'll need to set it up allot tighter than that! The clutches will compress after being run.
We install 8 Borg Warner High Energy clutches. 6 won't hold long at all. You'll need to play with the stack to get it right. Meaning, use a combination of different thickness steels and clutches.
Use a .065 clutch and a .067 steel to begin with and see how that looks. It'll come out somewhere around .022 - .028.
g
Old 07-15-2008, 01:37 PM
Rosco's Avatar
how do I set it tighter? by adding more steels/clutches?
I dont think I could fit another clutch in there though as there is .062 with the extra steel added
Old 07-15-2008, 01:38 PM
Take another look at my post.... I edited it for you.
g
Old 07-15-2008, 01:42 PM
Rosco's Avatar
Ahh that makes sense now! only had 6 clutches, guess I need to order some more!
Thanks for getting back to me so quick!
Old 07-15-2008, 01:46 PM
You're welcome. Timing is everything, looks like ours was good!
g
Old 07-15-2008, 01:53 PM
Rosco's Avatar
indeed! and you have saved me from messing it up!
Right place at the right time!
