firming up 3rd
firming up 3rd
i have searched but every1 is only recommending servos. i currently have my tranny off already has shift kit, 3200 pi stall and 1-2 shift is nice but i want 3rd alittle firmer is there any spring or pistons you can buy that will firm up 3rd i have the vet servo and will be getting a 1-2 actuator piston. any tips are appriciated. if i was to get a sonax 2nd gear servo would that firm up 3rd?
g
Sonnax claims that servo will firm up the 2-3 shift. I personally have never took a vehicle and made the comparison test. However guys with trucks go to the vet servo from the 553 servo to clean up the 2nd gear shift. The only thing that could be different with the sonnax piece is that the accumulator part of the servo could reduce the accumulation and firm up the shift. I do know when I have installed the internal parts into the servo the cover seems to be tighter than the vet servo when installing the snap ring. Also the sonnax piece uses d ring type seals instead of Teflon seals. This does provide for a better seal and reduces the reaction time of the circuit! Maybe there is something there to consider.
LS1Tech Sponsor
I have used both the sonnax and the fairbanks servo both will firm up the 2-3 shift to some what. The fairbanks more so from my experience due to great reduction of the 3-4 clutch accumulation, However since since they will both also firm up the 1-2 shift due to increased area it may be desirable to increase 1-2 accumulation at the same time particularly with the fairbanks. In either servos case I would only use if the band was and after market performance piece with reinforced band lug area as with the stock band tear through here is a real possible risk due to the increased clamping force of each.
__________________
i was told by the previous owner when i swaped it that it was AAA transmission in louisiana "It was a stage 2 build with a shift kit, upgraded servos, clutch pacs & sun shell" so no real specific but this was what i was told
LS1Tech Sponsor
Yes making this clear the 3rd clutch is indeed accumulated in the back side of the 2nd servo and used to release it and the 3rd direct clutch is called the 3-4 clutch, I am very aware that the 3 to 4th or fourth accumulator is in the case but that is the 4th accum not the direct clutch (3-4 clutch) accumulator. I guess my wording was not clear on the matter (MY BAd) as they say.
__________________
