Another 4L60e toast?
Yesterday I let a friend of mine drive my car home because another friend of mine was too drunk to drive. As I am heading home I see my car on the side of the road. My friend tells me "it just died".
I jump in and starts right up, but won't move. If you put it in gear, the rpm's climb alittle then settle back down and nothing. I got it towed home and I checked the fluid and its not burnt, might be a tad low but not much.
Sound like I lost a pump?
This is a fully built 4l60 with a Yank converter, I was hoping it would last longer then a freaking year :roll:
LS1Tech Sponsor
If you have no movement its likely a broken pump or a broken hard part "INPUT SHAFT DRUM , OUTPUT SHAFT etc" Though there are many possibles. I would unhook a cooler line a start first this will allow you to prove or disprove the pump as the culprit.
__________________
