video of knocking noise by my tranny..
does any one have any clue what can be wrong with my tranny by this video, i have no power in any of my 4gears..not even on 1st...i took the cover off to check out the flywheel to see if it was bent or some bolts loose but there was no bolts loose or off, i turned the car on and saw the flywheel spinning and it seemed fine, it was not moving like if it was bent..anything guys? when i was under i noticed the noise came behind the stall, can it be that the stall went out?? first time i ever heard this noise
http://www.youtube.com/watch?v=Aj6zBhz1KuY
im trying to upload some more vids of it, if more needed let me know..
make sure that the boltof the FlyWheel to converter are tight... Same problem on my 99 A4 LS1... Scared the S**t out of me too at first... If it continues you might want to check you flywheel that it is not cracked. Good Luck
