how to find picture of shift selenoid
Old 08-18-2008, 07:00 PM
dameter21's Avatar
Question how to find picture of shift selenoid
where online could I find a picture/diagram of what the shift solenoid b looks like so I can replace it.po756 (shift solenoid b ckt performance or stuck off).
Old 08-18-2008, 08:15 PM
LS1Tech Sponsor
performabuilt's Avatar
If this code is intermittent then before I would replace the solenoid I would have tha code turned off in tuning as it may be a false code caused by the stall. I am really amazed all tuner don't turn off the test for the shift solenoids stuck on or off whenever they are tuning for a stall as this comes up very often
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-18-2008, 11:56 PM
FLT
FLT's Avatar
Are you sure that it was not a P0757? That is the more common code for the B solenoid. Here is a quick picture for you. 1= a solenoid or 1-2 solenoid 2= b solenoid or 2-3 solenoid 3= pwm tcc solenoid 4= 3-2 control solenoid 5= epc/pcs solenoid. Vince
Old 08-19-2008, 05:57 PM
dameter21's Avatar
cool thanks for the pic it helps alot ..
