Best trans. fluid for 460LE ???
Old 08-31-2008, 08:28 PM
98Z28importslayer's Avatar
Default Best trans. fluid for 460LE ???
Im looking at changing my trans. fluid out on my 98 z28 A4 with 143k miles on the clock. Whats the best stuff i could get from a advance auto, autozone, or oreillys ?
Old 08-31-2008, 11:14 PM
LS1Tech Sponsor
performabuilt's Avatar
IMO stick with plan ole dexron3 or dexron mercron no sense in wasting money
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-31-2008, 11:44 PM
what brand would you go with ?
Old 08-31-2008, 11:49 PM
LS1Tech Sponsor
No particular preference "meets of exceeds" means just that
__________________
Call 888-744-6542
Old 09-02-2008, 12:17 AM
DeepV's Avatar
^^^ Like he said, what matters is that you change it frequently and that it stays clean.
Old 09-02-2008, 12:19 AM
GT Griller's Avatar
I use the cheap **** from vatozone.
Old 09-02-2008, 08:06 AM
TXZ28LS1's Avatar
castrol DEX 3 for me!!
Old 09-02-2008, 10:40 AM
BS@PMS's Avatar
I'm verry happy with Mercon V full synthetic. It cools down very quickly and is working very good. Since Ford trannies are garbage they had to come up with a better trans fluid and they did. Dont get the Dex/Merc stuff, get the Mercon V, I use Valvoline. Im sure you'll like it and its only about $5-6 at Kragen. I have a tranny cooler and I change the fluid every 10,000mi, but thats just me regardless of fluid brand because I drive my car hard and wanna be on the safe side.
Old 09-02-2008, 12:41 PM
Jared H's Avatar
I like this ATF ...
https://www.amsoil.com/storefront/atf.aspx
Old 09-02-2008, 12:49 PM
BS@PMS's Avatar
Originally Posted by Jared H
Thats what I was originaly aiming for but its hard to come by.
Old 09-02-2008, 04:02 PM
Johns00Z28's Avatar
How many quarts does it take to completely refill an automatic trans in a 4L60E?
Old 09-02-2008, 04:52 PM
MYSTIC-1SC's Avatar
if you go to gm to get the fluid they offer dexron 6, which the guy said replaces the dexron 3
Old 09-02-2008, 06:02 PM
GT Griller's Avatar
If its completely empty and so is the converter it takes atleast like 12.....i cant remember off the top of my head.
Old 09-02-2008, 06:33 PM
Johns00Z28's Avatar
Damn! How many qts make up a gallon? Wonder if it'd be cheaper to buy it in gallon containers rather than qts?
Johns00Z28's Avatar
Do you personally use Amsoil? I'd be interested to know if this stuff makes a difference.
Old 09-02-2008, 06:50 PM
NVmyVETTE's Avatar
I've used Amsoil in the past, didn't seem any different. I used RP and it would hesitate during the shifts?
I just use non-synthetic Castrol in my FLT now. Works just fine.
Old 09-02-2008, 06:53 PM
Johns00Z28's Avatar
Yeah I guess you'd need to test the conventional ATF followed by the synthetic ATF to see if there was any difference. But from you're saying it's probably not much of a difference if any.
Old 09-02-2008, 07:29 PM
69LT1Bird's Avatar
Dexron 6, if you have an aftermarket converter you will not need as much as a stock complete fill. A 10" converter holds about 3 quarts less that a production 300mm converter. Start at 9 quarts and check. It depends on the pan you have as to how much will will need also.
Old 09-02-2008, 07:33 PM
Johns00Z28's Avatar
Would it be beneficial to have a deeper pan or would that be for more extreme setups?
Old 09-02-2008, 07:36 PM
GT Griller's Avatar
4 quarts make a gallon
TRue, but when i first put in my old stall i still needed 12 quarts tho.
Quick Reply: Best trans. fluid for 460LE ???
