does anybody make this fitting???
I am installing a trans cooler and am leaving the the stock one in series too. I am using steel braided line. Does anyone make a fitting the goes into the radiator and is -6an on the other side??? so I think I need a fitting that is 5/16 inverted flare to -6an. if anyone has another idea please comment.
coolers
Yep, use the radiator too. Water to fluid converts more heat over out of the fluid than air to fluid. Plus, you loose some heat out of the tranny fluid to the radiator water, then you get the benifits of loosing more heat to the ambient air passing over the external cooler, best of both worlds.
dm
dm
