Stock 4L80E stronger than built 4L60E?
Old 09-14-2008, 12:35 PM
TS6
TS6's Avatar
Default Stock 4L80E stronger than built 4L60E?
I've heard from a not so reliable source that a stock 4L80E (maybe with a shift kit) is stronger than a built 4L60E? Is that true? I'm making 740 RWHP and the race weight is about 3600 lbs, and I know the 4L60E is on the edge at this level.
Old 09-14-2008, 01:04 PM
Gordon0652's Avatar
Stock for Stock, Yes. But a built 4L60E can handle 800rwhp and the stock 4L80E might do 400rwhp? Hope that helps some.
Old 09-14-2008, 01:23 PM
408z28's Avatar
There are guys on here running junk yard pull out 4l80e's with 80,000 miles on them running 700-800 rwhp all day long with no problems. All they do is put a good stall in, and roll. I would run a used stock 4l80e anyday over a built 4l60e. Just my $ .02
Old 09-14-2008, 01:33 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
youve got to think the 4l80e comes in 7k+ pound vehicles w/ towing capabilities of well over 15k in some applications
so figure a 3500ish lb car and no towwing. i would say you can beat them to death in anything 800hp and under i would think.
Old 09-14-2008, 01:45 PM
RamAir02TA77's Avatar
Yeah id probably take a stock 4l80e over a built 4l60e either way I could always have the 4l80e built and it will take huge power.
Old 09-14-2008, 02:00 PM
MUSTANGBRKR02's Avatar
Mine should be here in a week or so
Old 12-07-2008, 12:29 AM
Bersaglieri's Avatar
I kept blowing up stock and built 4L60e's. I got a $100 4l80e that looked like it ran on used 15w40, put a Vigilante in, FMVB, and it stood strong.
-Dustin-
Old 12-07-2008, 04:00 PM
Blk_Ws6's Avatar
How much extra weight will it add to your car the 4l80 I mean?
Old 12-09-2008, 07:00 AM
Restricted User
98Z28CobraKiller's Avatar
4L80 is a TH400 w/ overdrive. They're pretty strong. Is anyone making a FMVB that actually works w/o any glitches?
Old 12-09-2008, 07:47 AM
I'll let you guys know. I am going to be running Rossler's FMVB "plug in" and soon after his Transbrake. I already have a Transgo Stage 3 FMVB kit in use now. I might even give the Trinity one a try. I'll let you guys know in the next few months.
-Dustin-
Old 12-09-2008, 08:14 AM
the_merv's Avatar
I would put my money on a Stock 4L80E over a built 4L60E..
They are heavy though, like 225 lbs..
Old 12-09-2008, 11:35 AM
T/A KID's Avatar
The 4L80E in stock form is pretty heavy, considering it takes around 7.5 quarts of fluid and the STOCK converter weighs around 90-100lbs. My 4L80E with the ears cut off and a PY3400 converter weighed probably 30-40lbs AT MOST more than my 4L60E with similiar 3000 midwest converter.
Old 12-09-2008, 12:22 PM
cablebandit's Avatar
stock 80e converter weighs 73#...i weighed it
Old 12-09-2008, 12:35 PM
w3s1c0a5t's Avatar
What all is required for the swap? crossmember i know. What else?
Old 02-27-2009, 12:13 AM
Camaro Ken's Avatar
Great thread i'll probably be buyin a converter and a $350 4l80e tommorrow.
4l65e for sale!!! $650 o.b.o.
Old 02-27-2009, 12:15 AM
Camaro Ken's Avatar
think it'll blow with a transbrake on a 500hp 480tq. car with transbrake on the track once every 4 months?
Old 02-27-2009, 04:21 AM
Rickys S/C Z28's Avatar
im having my 80 built right now and im going to be selling a brand new 60w converter, i hope the 80 can live up to all the hype
Old 02-27-2009, 08:19 PM
Silver_TransAm's Avatar
My 4l80e is being built right now with a transgo shift kit and clutches. Thats all the this tranny needs for under a 1000hp.
Old 02-27-2009, 08:21 PM
The pan alone takes 7-8 quarts. The 80e takes about 14qts after a rebuild.
Old 02-28-2009, 04:28 AM
GMCtrk's Avatar
The 4l80e is rated to handle 440lb/ft of torque in an 8,000lb vehicle in stock form. There is no doubt in my mind that a 4l80e stock is stronger than a fully built 4l60e. You can polish a turd all you want, but in the end it's still a turd. The 4l60e is simply an inferiorly designed trans for the purpose of high power or weight applications (i.e. it was made to go behind a 200hp v6). That being said, when you are considering a 3,500 lb or less vehicle, a well built 4l60e is obviously viable as has been proven by some of the high powered vehicle running sponsor's transmissions here. Regarding half ton trucks though, it's a tragedy GM ever used the 4l60e in those vehicles, which is why I will be swapping right over to the 80 myself. I am not aware of what all is involved or how difficult the swap is into an F-body, but for the cost one can obtain a complete low mile 4l80e for, the swap is a no brainer in my opinion over a $2500 60e. Wet the 4l80e w/converter weighs 255lbs. In comparison the 4l60e is about 195lbs fully wet.
Quick Reply: Stock 4L80E stronger than built 4L60E?
