4l60e or 4l80e?
Old 09-16-2008, 09:57 PM
Gumby84's Avatar
Default 4l60e or 4l80e?
Was just wondering what is the weight differenece between the 2 transmissions the 60e and 80e. how much weight will the 80e trans add to a stock camaro. also with is a 4l65e? thx
Old 09-16-2008, 10:26 PM
Tech Resident
ChocoTaco369's Avatar
A 4L65E is just a 4L60E with upgraded bands/clutches and 5 pinion planetary gears. Maybe one or two other upgrades from the factory. They're the exact same transmission in reality.
A 4L80E weighs I think something like 50-70 lbs. more than a 4L60E. Don't quote me on that. I don't know the exact number. It's more than 50lbs. but less than 100lbs.
Old 09-21-2008, 03:35 AM
Blk_Ws6's Avatar
which is better?
Old 09-22-2008, 09:57 AM
koolaid_kid's Avatar
The 4L80e is supposed to be far stronger than the 4L60e. If I were to chose, I would select the 80 over the 60 every time.
Old 09-22-2008, 10:02 AM
Tech Resident
Originally Posted by Blk_Ws6
which is better?
The 4L80E will hold gobs more horsepower than the 4L60E. The 4L80E when built right will easily take you north of 1000rwhp. Those transmissions were built for 6,000 lb. busses. A 3500 lb. street car is a piece of cake for them.
That being said, they also weigh a lot more than a 4L60E, eat up a lot more horsepower due to parasitic losses and need modifications to fit, making the swap somewhat difficult and more costly. If you have a 1000 rwhp street car and you need overdrive, they're pretty much your only option, but for the vast majority of guys on this site, they're overkill and will just weigh you down and eat up your power.
In short, what is better depends on your application.
Old 09-22-2008, 08:52 PM
RamAir02TA77's Avatar
Id rather have overkill instead of paying to get 4l60e's refreshed often. But I believe the weight difference is less then 100lbs.
Old 09-22-2008, 09:02 PM
Blk_Ws6's Avatar
YOUR SO RIGHT DUDE i can't keep buying these trannys i want something that will last.
Old 09-22-2008, 09:04 PM
Blk_Ws6's Avatar
hey bro how much did it cost (4l80e) and did it weigh you down alot?
