th400 manual valve body
I am getting a built turbo 400 trans with a manual valve body and a 3000 stall.
Now will i be able to choose what gear i want it in. Cause with my 4l60e i would put it in first and it would still shift in to second. And a stall is how high the rpms will get before you move or how high it takes to get the tires to spin when the brakes are down.
I have a reverse manual valve body other then the order of gears, im not sure if the two are different but if they are the same then, yes you will have to shift every time you want it to go into what ever gear. And is your last statement a question or a statement? As i have a 3600 stall and it does no tneed to rev up to 3600 in order ot start moving. But it will really let loose at 3600.
Also did yo ureally want the manual valve body, i really prefer the reverse manual as that way third is all the way back and farthest away from nuetral
