PICS of T400 tranny lines. Or what did you do with yours
Getting ready to install my performabuilt T400 and I ordered a set of tranny lines from jegs. The braided set with all the fittings. How do you guys have your running up to your tranny cooler? I also have heard of people cutting there stock tranny lines and running a braided one out of the tranny a couple of feet out and attaching it to there 4l60e lines with clamps.
pics would be nice if anyone has any. thanks
I used summit high temp blue with all AN- fittings same difference..Got a tranny cooler mounted in between where the bumper reinforcement used to be, lines come out of the tranny on a pair of -6 45* "with the 5/16 flare adapters removed the tranny case is 1/4 npt" kinda loop up beside the transmission to keep away from my LTs then run right up under the starter go to the outside of the radiator on the right and then come up and around to the space behind the front bumper..All hoses are neatly zip tied together looks very clean and away from all heat sources...My oil pump is giving me fits but I will have my car back home tomorow so if you still want let me know and I will get you pics soon as it makes it home gotta trailer it..
How do you run the flimsy lines from the tranny to the cooler in the front. I thought about getting those plastic clamps that wrap around the line and have a hole on one side and screw it to the fram.
