question on 4l60e
question on 4l60e
buddy and me were out cruisin around for a couple hours went down a couple of twisty roads and at the end of the road he was goin around the corner and bumped it into neutral now when he puts it in gear it will drive for about a min and then start slippin and eventually wont do anything plenty of fluid and everything but seems to slip alot wen its hot any ideas
LS1Tech Sponsor
Well he could go that route or a smarter route would be to go with a sponsor from here and just get a trans. For instance our level 2 right now is 20% off this week making it $1472 and its a whole lot more than just a rebuild. The other sponsors here build excellent units also. If this is a performance car used as such and it sounds like it is I certainly would not even consider just a stock rebuilt
__________________
$1000 local rebuilds are asking for trouble......no way would i let anything less then a 4l60 expert touch mine. im sure any trans sponsor here could fix you up.
