You aint gonna believe this trans mount was less then.......
Old 10-06-2008, 12:27 PM
onebadazzls1ta's Avatar
Default You aint gonna believe this trans mount was less then.......
A day old and I already broke it, It was a 2817 anchor mount I called rock auto and they are sending me another one for free because this wasnt their fault. They showed the 2817 has not being a good part # for my 99. This is the last time if it breaks again it looks like I'm SOL which I'm sure it will.
Old 10-06-2008, 01:05 PM
GT Griller's Avatar
Man i broke aftermarket tranny mounts left and right....put a stocker back in and been fine for almost 1yr and a half.
Old 10-06-2008, 01:14 PM
so you'd consider an anchor mount to be aftermarket LOL. I know I shouldn't skimp on something so important has my trans mount. What unit are you using?
Old 10-06-2008, 03:20 PM
GT Griller's Avatar
I used the energy suspenion or suspension enegery or what ever its called....that hoe broke to many times...went back with a new stock mount from the the dealership and no problems.
Old 10-06-2008, 03:51 PM
um wow you broke an es mount? JESUS MAN what are your shift points set at? I know my 1-2 are a kick in the ***. I see you have a vig and richmond gears I can see why you where breaking them.
Old 10-06-2008, 04:37 PM
daniel6718's Avatar
broken tranny mounts are mostly from bad motor mounts...fix the mm and the tranny one will be fine
Old 10-06-2008, 04:43 PM
shaun's Avatar
i broke a few stock ones and i had a prothane poly one that was horrible.
i ended up going with a 1le tranny mound and it has been fine for close to 2 years.
i got it from thunder racing and it cost about 40-50 bucks.
its stiffer that the oem but not as stiff as the poly one.
Old 10-06-2008, 05:27 PM
I'm on spohn solids
Old 10-06-2008, 06:07 PM
FLT
FLT's Avatar
+1 on the oem factory mount from the dealer. Not sure if poly mounts are a good choice for a mild street car/DD.
Old 10-06-2008, 06:19 PM
the only problem is with the factory mounts they are gonna have alot of give.
Old 10-06-2008, 07:48 PM
crzytown69's Avatar
i have prothane mm and i tried the prothane tranny mount broke the tail shaft 3rd pull on the dyno... +1 for the stock mount
Old 10-06-2008, 09:06 PM
Yeah that's what I'm worried about is breaking my tailshaft how much you puttin to the wheels?
Old 10-06-2008, 09:23 PM
Rhedalert's Avatar
Anchor is the worst mount manufacturer in the entire milkyway galaxy. I've broken every one I bought on V6 front drive cars!!! Pieces of trash!!!
Old 10-06-2008, 09:26 PM
gee let them know how you really feel LMAO
Old 10-07-2008, 02:13 PM
why are the 98 and up trans mounts so hard to find? oh I don't know if any of you knew this but the anchor part # 2817 is for 97 and under I checked advances system and that's what it's listed for. Btw I have another one coming from gm direct.
Old 10-08-2008, 01:09 AM
Rhedalert's Avatar
Sorry, it was just frustrating to change a motor mount 3 times on a car with 140 HP
Old 10-08-2008, 06:55 PM
Why is it sooooooo impossible to find the 98 and ^? even gmpartsdirect was a special order.
Old 10-08-2008, 09:07 PM
FlashLCD33's Avatar
I've broken/seen many broken aftermarket mounts, GM works the best that i've ever seen.
Old 10-08-2008, 09:47 PM
That's a good thing LOL it sucks not being able to get on it without worrying about the trans comming crashing throught the floor boards LMAO.
Old 10-09-2008, 10:34 AM
crzytown69's Avatar
im only putting 426 to the wheels
