The best way to Retrieve Chrysler Fault Codes
1. Locate the information hyperlink connector within your Chrysler. The DLCs are often situated beneath the steering column auto diagnostic.
It is possible to uncover the exact place, typically with a picture of your location Vehicle Diagnostic equipment, on the DLC locator website listed inside the Resources section.
2. Plug the OBD reader into the data hyperlink connector and initiate the device.
3. Follow the reader’s directions for retrieving the fault codes from the onboard diagnostics program.
4. Read and record the fault code(s) offered by the OBD reader.
5. Compare the code(s) towards the ones listed on the Dodge/Chrysler/Jeep/Plymouth OBD-II Trouble Codes page listed in the Resources section to decide the problem together with the Chrysler.
