OKC GM plan to eliminate 2nd shift
Deranged Rat Fink
1 Post
Man , that does suck! I work at the Peterbilt plant in Madison,Tn. You've always got the threat of layoffs looming over your head because if the economy takes a turn for the worse , they start cutting back on labor.You try not to think about it too much because it will drive you crazy if you do. I wish the best for you and I hope everything turns out ok for you in the aftermath.
