Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What type of pistons are in the CTS-V calipers?
Old 09-05-2010, 08:16 AM
JimMueller's Avatar
Default What type of pistons are in the CTS-V calipers?
Doug Rippie sells stainless steel pistons for the C5/C6 and C6Z calipers. The stock pieces are apparently aluminum. Can anyone confirm what type of piston the CTS-V calipers have? If not stainless steel, would either of these parts be compatible with the CTS-V calipers?
C5/C6 http://dougrippie.com/?p=425
C6Z http://dougrippie.com/?p=414
Old 09-05-2010, 08:52 AM
raven154's Avatar
I believe Brembo does use SS. The Z06 doesn't use Brembo calipers.
Old 09-05-2010, 10:10 AM
killernoodle's Avatar
Aluminum. I just did my brakes yesterday and when I was prying the pistons back, I noticed I dinged one of them.
Old 09-05-2010, 11:02 AM
raven154's Avatar
That's interesting. I've got a junk rear caliper that I can tear apart. I've been wrong before though.
Old 09-05-2010, 01:33 PM
Gus_Mahn's Avatar
I'd say the bores are bore important than the pistons. Is there a liner in there or does the seal ride on an aluminum bore?
Old 09-05-2010, 02:03 PM
JNR_Design's Avatar
If you were to replace aluminum with stainless, just keep in mind the different expansion rates of the materials, when you machine them, etc...I imagine a good shop will do this, but if you were to do this yourself, etc...doubt this is a big consideration, but maybe it takes a little more hydraulic 'power' to move SS vs. alum. Probably not, though on such a small movement.
Old 09-05-2010, 03:37 PM
raven154's Avatar
Yeah the backs are aluminum and they also look hard chrome plated. Most likely just for a little more durability.
Old 09-05-2010, 08:48 PM
Gus_Mahn's Avatar
2-stroke dirtbike cylinders are chrome over aluminum, and it's very durable.
Quick Reply: What type of pistons are in the CTS-V calipers?
