Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What could be causing this? **video**
Old 10-06-2010, 06:26 PM
whisler151's Avatar
Default What could be causing this? **video**
Ok, i've been posting about this issue for a while now and got a good video of the issue. It seems that if I turn the wheel at idle the RPMs drop near 500 and when I turn on the AC it drops to 500 and then to 250.
Is this a tuning issue or something else?
http://www.youtube.com/watch?v=NYP_miUvnrI
Old 10-06-2010, 07:35 PM
Remo's Avatar
I think its called Idle air control. When u turn on the ac it should idle the car up.
Old 10-06-2010, 09:37 PM
itsslow98's Avatar
I still think its some kind of power issue. IAC could be a culprit also though. Mine dips a little when i turn the a/c on but after a few seconds it goes back to normal.
Old 10-06-2010, 10:16 PM
STAGEUP's Avatar
Zero out your a/c torque
Add some airflow to your main idle airflow table
Old 10-07-2010, 04:42 AM
maxspeed05V's Avatar
Its because of your cam. ( From what I remeber your running a serious one too)
My car did the same thing just not as bad ( my cam was milder then yours) . What I had to if I wanted to run the a/c was set it on while the car was parked and idling. And let the car learn it self for about 30-60 seconds. Made it alot better .
Go back to your tunner see if he can dial it in better
Old 10-07-2010, 06:31 AM
whisler151's Avatar
Cool, i'll try that.
Thanks!
Old 10-07-2010, 11:12 AM
whisler151's Avatar
I sent the video to my tuner and he knows exactly how to fix it.
Old 10-07-2010, 12:32 PM
ColeGraham's Avatar
I <3 SNL
and yes i did just type like a Justin Bieber fan
Old 10-07-2010, 10:22 PM
itsslow98's Avatar
I have the opposite, if i turn the a/c on while driving i have no problems at all, if im idling and sitting still it needs to learn the idle. its definetly not as bad as whislers though
Originally Posted by ColeGraham
I <3 SNL
and yes i did just type like a Justin Bieber fan because I am one
fixed that for ya
Old 10-08-2010, 11:37 AM
ColeGraham's Avatar
Originally Posted by itsslow98
fixed that for ya
eff you allen...haha
Old 10-08-2010, 08:30 PM
bamacaddy's Avatar
BAHAHAHAAAAAAAAAAAAAAAAAAAAAA
