Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Stroke my LS2 or get a stroker LS3?
Old 11-14-2010, 10:37 AM
CTS-V Shifter Sales
07CTS-V's Avatar
Default Stroke my LS2 or get a stroker LS3?
I'm trying to decide what to do. What do you guys think? Here are my 3 options that I'm contemplating.
1. Machine my stock LS2 block and build it up with a 4" stroker kit. I'm looking for about 500 to the wheels with this setup. This will cost me roughly $4000 in parts and machining.
2. Purchase a 402 short block and achieve the same results as #1, but I'll have my current bottom end (which needs work) as a backup or sell it. This option is about $500 more than #1.
3. Purchase a 418 stroker LS3 short block and build it up with a cam, heads and intake. This will cost about $1500 more than #1. Any ideas how much this would get to the tires? I was thinking it should be over 550, but I'm not sure.
Old 11-14-2010, 01:59 PM
JJSimon904's Avatar
If you have the cash, option #3...it all depends on your budget
Old 11-14-2010, 05:29 PM
itsslow98's Avatar
Machine the stock ls2 shortblock, buy a set of l92 heads and an LS3 or FAST intake with a nice cam and make around 500.
Old 11-14-2010, 06:09 PM
scatillac's Avatar
The first part of this thread deals with a 402... https://ls1tech.com/forums/generatio...b-c-d-e-f.html
Plenty stout, basically your option 1, but with the L92/LS3 type heads and a little help from Virginia Speed.
Old 11-14-2010, 06:24 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I was planning on a 242/250 .614/.614 114lsa along with some stage 3 Patriot heads that have larger valves and port my stock manifold. That should get me to 500.
I just need to figure out how much modification needs to be done to use a stroked LS3 short block with supporting heads and intake.
Old 11-14-2010, 09:41 PM
itsslow98's Avatar
I could be wrong but even a ported ls2 intake is gonna be a huge choke on the motor with a stout heads/cam setup.
Old 11-14-2010, 10:35 PM
liqidvenom's Avatar
the thought of an ls3 under my hood would be awesome.
Old 11-15-2010, 04:21 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I'm also thinking about having an LS7 under my hood, but NEVER saying it.
Old 11-15-2010, 07:39 PM
ColeGraham's Avatar
i like this one
Old 11-16-2010, 02:19 PM
n2o402's Avatar
Default 402
Option1 good as it gets stick with your ls2 block machine it and buy u a stroker stick with ur 243 heads when ported you'll be plenty happy this setup with a big cam will give u over 550 to the wheels with a little more money in your pocket at te end
Old 11-16-2010, 03:48 PM
scatillac's Avatar
This works too!
243s are good heads, but in the larger displacement motors, you can get the same power with less cam with the stock L92/LS3-type heads (and more if you have them "cleaned-up a bit" ).
This will make for a much nicer driving car, but I guess that it's a matter of personal preference. Since the car is relatively civilized to begin with, I just preferred to keep it that way.
Old 11-16-2010, 05:25 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Youre not getting 550rwhp out of a 402 with 243s and a ported ls2 intake
I personally like the larger bore motors since they have many more head options and less valve shrouding. If it was me Id do the 416 LS3 stroker with a set of ported L92 heads from WCCH and an LS3 intake or if money allowed or later on a FAST setup. Id put all my money into the long block first and let it be choked at the intake then as money allowed switch the induction. Its much easier to change an intake than heads.
Old 11-16-2010, 06:09 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I'm leaning towards the 418 LS3 with a set of PRC LS3 P&P heads and a ported LS3 intake.
Old 11-16-2010, 06:56 PM
itsslow98's Avatar
shoot me a PM if you decide to sell the ls2 shortblock
Old 11-16-2010, 07:50 PM
1slow01Z71's Avatar
Give Richard at WCCH a call, you wont ever talk to a nicer, more knowledgeable guy and he makes some pretty slick ****
http://proheads.com/
818-705-5454
Tell him Cody sent you and he'll either give you a discount or charge twice as much
Old 11-16-2010, 08:14 PM
CTS-V Shifter Sales
07CTS-V's Avatar
Will do.
Old 11-16-2010, 08:23 PM
Stepside's Avatar
Brian, screw N/A.
Forge the bottom end.
Then, put a good blower on it.
Both heads will feel great when they're blowen . .
Miss Whipple or Miss Maggie 2300 will twist your crank . .
Old 11-16-2010, 09:08 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I'm sure a 4.0L Whipple on an LS3 stroker (or 440 LS7 stroker) will be in the future, but most likely not in the V. It'll be way to much work to get the rest of the car up to the task. This upgrade will hold me over for a couple years just like the initial head & cam upgrade that got me to 440 N/A rwHp.
Quick Reply: Stroke my LS2 or get a stroker LS3?
