CAI difference between V1's
Do any of you fella's happen to know the difference between the cold air intake kits for 04-05 and 06-07?
Volant and K&N have the years split up with corresponding part number differences. I was under the assumption that the TB's 04-07 all had the 4" lip and same MAF sensor.
I have an LS6 and have a fast intake with LS2 tb on the way and need to know which cai to go with.
If you have a 90 on the way, I'd use the LS2 kit. The only difference is the LS2 kit has a nipple on the intake tube. The old 78mm TB had a nipple that gets deleted with the 90 and the hose needs a new home.
You can make an 04-05 volant kit work on the 90, you just need to drill and install a nipple into the intake tube. Thats what I have done. Well almost, the nipple is in the cup holder awaiting its new home.
good to hear some discussion on this topic, as i am in the dilemma of what intake to go with... looks like the stock intake and a drop in K&N filter will be the best route for me to go... nice and cheap!!
