Engine mounts?
Devil Dog, OohRah!
Engine mounts?
So I had the V in the dealership for the 50k service, and they said the left engine mount was bad. How do I check this for myself? If it does need replacing, how hard is it to change and how do I go about it? I looked on alldata or whatever and they had nothing, and there is no Haynes manual for a V (according to my wife and Autozone).
Devil Dog, OohRah!
Well, damn. Last time I had it up, I'm pretty sure I saw yellow-brown drip like stains down there. Anyone know how hard it is to change them? I have access to a lift and tools for another week.
When my passenger side was bad, I had the coffee stains, and I could see the engine move a bunch with a light clutch pop in reverse with the hood open. It also shook and rattled a little more than normal when I turned the car off.
As the link posted below shows...You can do it yourself...and apparently in your driveway. If you read my comments on this, I was super impressed that he was able to do it without a lift. I did help out when I had mine changed....Did it on a Sunday when the garage was closed....Just had to remove more parts than I expected to get to it. Getting the flattened out ones out wasn't the issue, for us it was getting the new ones back on since they were almost double the height since they weren't "squeezed out". All I can say is BEST OF LUCK and you definitely wanna make a beer run before you get started.
Yep did it in the driveway following two videos on youtube! The video was made by a employee of creative steel showing how to install there mounts. It took me about 6 hrs and I took my time.
Coffee Stain...yummy
What the mounts looked like...
Mine had had 33322 on them when they took their dump. i did not install them myself, because at the time i didnt feel like it. like D said, it is fairly straight forward and simple. if you know your way around a car (and judging by your sig, you do) it can me done easily.
Just had mine replaced under warranty...not sure which ones. It made a significant difference in response and performance. This is now my 2nd time in 2 1/2 years having engine mounts replaced. I plan on replacing them with CS mounts the next time, once off of warranty.
The way I knew wasn't as much of the "dieseling" at shutdown, like most people say. In mine, I had a [B]HARD SLAMMING[B] when I shifted hard. It was like the engine would slam against the frame or mount when I would press the clutch and then it would "yank" against the mount when I would torque back on it after shifting. This was due to the mount being blown out and having 1-2" of slack in a mount that is supposed to be somewhat rigid. I have the stockers back in mine now, and have some VERY spirited launches and driving on them....But I will go back with a set of CS ones once I blow these.
Devil Dog, OohRah!
EDIT: After utilizing the search function, I have ordered some mounts. Thanks guys.
Also, sorry for somehow missing a thread that was only two days old answering my exact question.
