Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Money to spend on V
Old 01-04-2011, 08:15 PM
mrwill76's Avatar
Default Money to spend on V
EnglandGreen Cam Package! We have been getting a lot of requests to do another cam special so here it is! Normally $2995.00, our cam package will be $500.00 off and is $2495.00 parts, labor, and tuned! Jump in now, because pricing will be going up next year!
I have the money for this set up or should i go another route? Let me know your opinion.
EnglandGreen Custom grind cam
GM Front cover gasket
GM Front cover Seal
GM Water pump gaskets
GM Crank bolt
GM LS2 timing chain
GM Oil pick up O-ring
High volume, High flow oil pump
160 Degree thermostat
Patriot Extreme dual valve springs with titanium retainers
7.400 inch chromemoly pushrods
Powerbond SFI 25% Underdrive Pulley
New Belts
Professional Installation
Street and Dyno Tune
Old 01-04-2011, 09:29 PM
itsslow98's Avatar
DOnt see the Special pricing in that to be honest. $2,000 is about the going rate for everything above installed and tuned.
Old 01-04-2011, 09:31 PM
SoJersey05V's Avatar
power?
Old 01-04-2011, 10:33 PM
ColeGraham's Avatar
i would have to agree...i know that i can get most of that done (some i dont need or already have) for 2000 or less.
Originally Posted by SoJersey05V
power?
depends on how you spec the cam...
Old 01-04-2011, 10:37 PM
itsslow98's Avatar
power?
more then a 2011 subaru i can say that haha
Old 01-04-2011, 10:38 PM
ColeGraham's Avatar
CALLED OUT! haha
Old 01-04-2011, 10:56 PM
mrwill76's Avatar
who can do the work for less than that in Texas? Or should i start with headers, tune and a clutch?
Old 01-04-2011, 11:14 PM
itsslow98's Avatar
SNL, texas speed. the list goes on.
Id start with long tubes first that was the best mod ive done so far. I wouldnt bother with a clutch until it goes on you. Im on my stocker.
Old 01-05-2011, 02:54 AM
GhettoTy's Avatar
This, and do a shifter instead of the clutch if you haven't already.
Old 01-05-2011, 07:51 AM
whisler151's Avatar
Mine was $1300 out the door for cam job at SNL. Cam, gaskets, dual PRC springs, PRC chromoly pushrods, fluids, tune and tax.
This was during a special, but I think their normal rate is $1400-$1500 max.
Old 01-05-2011, 08:39 AM
itsslow98's Avatar
add 200 for the u/d balancer since its no labor to put it on. and bam 800 less then the OPs price.
Old 01-05-2011, 03:44 PM
ColeGraham's Avatar
And SNL does custom grind cams as well. and they are very good at what they do. haha.
you will find a few guys on here that go there, and wont go anywhere else. if you are around DFW, go to SNL. i live in Abilene, and thats where i go...all 180 miles to get there.
Old 01-05-2011, 09:11 PM
mrwill76's Avatar
I'm glad I talked to you guys. I called SNL up today and they are ready for me to come in. The price they gave me was pretty good. I ordered my OBX headers today so i will gain a few ponies from that too. they told me with the headers and cam i should get around a 75+ horse increase.I will try to install the headers my self to save a few dollars on that. I will get the CAI later on, plus some guys on here will say the it soaks in a lot of heat or no hp gain with the CAI anyway.
Old 01-05-2011, 09:19 PM
ColeGraham's Avatar
no problem...i know i will be going back to SNL very soon. when you do you headers, look for motor mount issue. mine where shoot at 33322 miles so i had them replaced.
with the CAI, it depends on which one. K&N heat soaks like a Mo Fo.
Old 01-05-2011, 09:28 PM
mrwill76's Avatar
did you do aftermarket or factory, i know the UUC,s are high dollar and will set back my build. is there an alternative to thoses.
Old 01-05-2011, 09:37 PM
ColeGraham's Avatar
i went with UUC they are 290ish for the set. they feel like stock, but they are way stronger and wont turn my oil pan brown. the new CS mounts arent bad from what i here and they are a little cheaper. i didnt go with the CS because when i did mine CS were having a melting problem. the problems have been fixed (from what i here so far) with the newest CS mounts.
Old 01-06-2011, 05:20 PM
mrwill76's Avatar
CS motor mounts just got ordered. cant wait, CAI will be next.
Quick Reply: Money to spend on V
