new trans installed but hard to shift and drivetrain whine presists - LS1TECH
The Caddy with an Attitude...
Thread Tools Search this Thread
Old 06-16-2011, 10:19 PM   #1
Default new trans installed but hard to shift and drivetrain whine presists
I have 07 V with 72k and took it in for drivetrain noise. I figured diff but dealer instead replaced trans with new unit and also replaced clutch slave and clutch switch as they found it hard to shift when taking it for test drive. I get the car happy it has a new trans and slave but its really hard to shift gears now. Shifting up to 5th or 6th and back down to 5th from 6th especially takes a lot of force and precision. I have a pisnuoff modified stock shifter and bushings. Also to boot the drivetrain noise is still present. They agreed to look at again on Monday after waiting 12 days for a new trans to arrive and be installed, but any ideas what either of the issues could be?
I did some searches and plenty of people state their diff's whine which is why I took my car in to begin with but could a motor mount cause this sort of issue or maybe the clutch has finally given up. One of the motor mounts was changed about 40k ago and afaik its the original clutch. I am sure the clutch is due but are certain gears harder to find as the clutch starts to fail?
The drivetrain noise is from 2k-3k rpm in 4th-6th gears and also when engine braking through that rpm range, can hear a higher pitch noise coming from either trans or further downstream in the drivetrain.
garrettg is offline   Reply With Quote
Old 06-17-2011, 09:55 AM   #2
Skidmarcx's Avatar
I know that bad mounts can cause shifting difficulty... I had problems before I changed mine out. A bad clutch can also cause the same problem... air in the system can do it as well you might try bleeding the clutch. As far as the noise... without a sound clip it's hard to say other than the diff is most likely the culprit.
Skidmarcx is offline   Reply With Quote
Old 06-18-2011, 07:04 AM   #3
RADEoN's Avatar
I guess its possible they didn't bleed the clutch right, although unlikely.
RADEoN is offline   Reply With Quote
Old 06-20-2011, 12:09 PM   #4
Update: Dealership is ordering new diff but says small amount of whine is normal. Also states new transmission is tight and will take some time before 5th 6th gears can be accessed easily in all situations and motor mounts were said to be ok by dealer.
I suspect the clutch is dragging but will give it some time. I have planned to do a ls7 clutch at some point this year but if this thing doesn't loosen up in the next few weeks my hand will be forced to go ahead early with it.
Old 06-27-2011, 05:02 PM   #5
Update: New diff installed today will update later tonight if its quiet.
Old 06-27-2011, 10:44 PM   #6
Solved: Serial 0006450001210E installed (assume this is gen4) and its quiet. I could always get noise around 2-3k in 4th/5th gears but now all I can hear is the stump pulling ls2.
Old 06-28-2011, 07:43 AM   #7
.Houdini.'s Avatar
Awesome. Glad you got her fixed up.
.Houdini. is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
T56 issues. Any idea what's going on? cnw8891 Manual Transmission 0 03-12-2015 10:40 AM
Gto t56 gear noise... Help! initial_eg Manual Transmission 3 10-20-2013 10:47 PM
Help with Trans/Shifting Issues stevo92z28 Manual Transmission 0 12-23-2012 11:10 AM
Differential has major leaks and noise... (with pics) colospgsTA Gears & Axles 10 05-10-2012 03:21 PM
1st gear whine from new monster clutch setup 2001z Manual Transmission 12 08-22-2010 04:22 PM
Tags
cadillac, change, clink, cts, ctsv, gears, install, installed, motor, mount, noise, shift, tough, transmission, whine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
