Looking at some used V's and need some advice
So I'm beginning my search for a used CTS-V, and have found 2 options, both in the low $20k's:
2005 CTS-V, 40k miles
2007 CTS-V, 65k miles
Both are basically the same price. The '05 is from a Mercedes Dealer, and the '07 is from a generic used car sales place. Both have clean car faxes with one owner. Both are manual, and comparable condition. Which do you think is the better option?
Thanks for all the feedback
Are they similar enough that if I testdrive the '05 I would have a good feel for what the '07 feels like? I just ask because the '05 is much closer to me. I recently drove a C6, (which is why I'm looking into these in the first place), so I am curious to see how much of that driving experience translates to the caddy before I make the trek to look at the '07. Thanks!!
If the 05 and 07 have the same condition of motor mounts, trans mount, diff bushing mount, and clutch wear, they should drive the same. Depending on the condition of those parts, they could drive drastically different. I would certainly try to drive both and make your decision then.
Do either of them have the fg2 shock package? If so, you will notice a firmer ride.
When I sold my 07, I had 47k miles on the factory fg2s. They were perfect and handled very well. No leaks. I do remember reading that other owners had failures around the 30k mark but mine were still running strong.
I know this will cause an uproar but motor/trans mounts will probably be the leading cause to it driving poorly as it can affect general vibrations and how well it shifts, startup and shutdown. If the car has a short shifter and those items are bad which is probably common it could also be very hard to shift and give you a negative impression of the car in general. I would get the 07 if the price points are similar based on items mentioned as 25k miles is 1 year driving for me so that seems worth the tradeoff for the updated items. An 05 with upgraded diff and axles would probably level the playing field on a stock 07. FWIW, I upgraded the axles on my 07 and have not increased the power so upgraded axles are preferred for all years.
'07 should still be under a powertrain warranty. Also that is too much (IMO) for a 40k mile '05.
A friend of mine has an '07 C6. It is faster, has more tire, and feels generally edgier. The V feels more like a normal car, except everything is faster than a normal car. Also the driveline and shifter in the C6 feels normal, which is odd since it has a longer linkage and a dual-mass and those rubber donut things at the end of the driveshaft.
