2005 cts v suspension problem
ok if i go over big bumps nothings wrong when i go over small bumps an cracks i can hear a thump an cluck noise on each side of front wheels an can feel it in steelering wheels its soo annoying it pissies me off about to take it in the shop
i had a clunk noise on my V a few months back- did some swap bar end links and it fixed it up. your going to need to check the suspension to see if you have anything loose- you can chase clunk noises for a while by throwing parts at it
I took my driver side wheel off to see what's up but everything was fine that's where most of its coming from an I did notice steering shaft makes a clunking noise idk if it's that do they go bad? Car has 74000 miles
Mine makes a popping sound I can also feel I'm the wheel when I turn left especially if I am coming out of my apartment driveway going from an incline surface to a level one. Figured it was sway bar bushings. May do Z06 links & see if that fixes it.
