Fuel Pump / MSD Boost a pump troubleshoot
I have an 05 V with an STS turbo kit. The system uses the MSD 2350 boost a pump. I ran the car low on fuel this week and it died. I have filled the car and it will not crank. In the past, I have had the fuse wire lead to the BAP melt and replaced it. I have troubleshooted the BAP as much as I can. I was wondering if:
1. Is there a trick to the stock system if ran low on fuel?
2. Can I bypass the BAP for now to eliminate it as the problem?
