Ground Control Spring Rates
Hey, I've got the 550/600 lb springs on my Ground Control kit. Frankly, the car still bucks and leans a little bit too much for my taste.
For the rest of you with GC kits, what spring rates are you using and how do you like it?
Would you recommend new sway bars?
Which shocks are you running?
Sways are cheap, and would help. I removed my hotchkis from the front. Went through two sets of brackets, and got tired of fixing this clunk or that clunk.
What do you mean by "buck? As in the rear end shifts around over bumps when cornering? If so, my car does this pretty bad, and i'm confident it's just crappy engineering, not a mechanical problem with the car. Sounds like i'll have to do some research to get up to speed.
What shocks are you running? If stock fe4s, and they are worn, that makes it lean bad. It's stiffer and lower now. If they are really gone, even if you have sways, it will have that loose snap body roll. You really have to compliment it with shocks to enjoy it. The fg2s have alot of compression which keep you flatter in the turns.
I highly recommend the sways if your goal is to kill a good amount of body roll.
I have 500/550/600/ and 650 springs and have been trying out various combos for a while including fg2,fe4,qa1, etc.
I found that with fg2s, 500/550,sways, and ride height about 26.5 Front and rear, it was perfect. Very firm and planted, enough give to still have fun..
I stepped up to 550/600 and then 600/650. The stiffer springs only made things marginally better for the street, making it almost too stiff. The bumps are just rougher. Very flat and harder to push the car, you just can't find room to have fun. On a track I can see it being really nice.
I also tried qa1 shocks which in my opinion blow, but I'm having them rebuilt to my specific request so we'll see how that goes.
