LS-9X clutch, difficulty shifting while not moving
So i bought an installed a ls9X clutch with a brand new CTS-V slave. after completing that, there was difficulty shifting when the car was not moving (as if the clutch disc were still spinning a little with the transmission. Shifting while moving was a little notchy but okay. I then went ahead bought a brand new master cylinder and replaced that also. Still have the same issue, what do i look into now?
BTW, it has been bled countless times. I am certain it is not air in the line.
that clutch kit is made for the CTSV slave. I did the same install. LS9x twin disc & pressure plate, Tick remote bleeder, CTSV slave. how tight do you have that nut on the bottom of the shifter?? too tight or too loose seems to make it real notchy.
I know you say you have bled, but I notice you can never bleed enough. Once you get ALL the air you will be done. Until ALL the air is bled, it will not be smooth. I bled mine like 3 or 4 times over a few weeks period. good luck.
Keep bleeding it. Also, how are u bleeding it??
