tpms sensors and dr
tpms sensors and dr
Hey guys i have a v1 yhat im going to be puting some m&h dr on.ill be running about 11 to 15psi in them. I need to know if the low psi alarm in the tpms system will handycap the cars prefomance any. If so i can just put the tpms sensors in the front tires so the car wont see the fault.
Thanks guys
-alex
Thanks guys
-alex
Performance won't be affected, however you won't be able to put the car into competitive driving mode. That goes for either having the sensors installed with the tires aired down, or not having sensors in the rear at all. However that shouldn't be an issue as you'll likely want to defeat traction control as well as stability control for the drag strip.
Mike
Mike
Troll Banned For Creating Multiple Accounts (thebigjmsho, JimmyHemroid, AND Junior1))
Mike
Mike
As far as HP Tuners, no idea
I normally swap out tires for track days (all 4) they don't have TPMS in them, and by the time I make it to the track (1 Hr) the car has figured it out, and lets me put it into competitive mode or stability off mode.
I also know of some guys that placed tpms in some pvc pipe with endcaps, and pressurized it, then threw them in the trunk, that way the car sees the pressure is all good.
U cannot mess with the tpms with hptuners. The tpms is part of the bcm, not pcm, and hptuners is unable to communicate with the bcm. U can however shut the tpms off with a tech 2. Or u can just remove the tpms sensors all together and disable the tpms that way.
Cadzila's Banned Troll Account
Hmmm.....
