Rear Diff Bushing Replacement Help - LS1TECH
The Caddy with an Attitude...
Thread Tools Search this Thread
Old 08-07-2012, 08:48 AM   #1
Default Rear Diff Bushing Replacement Help
So I set out to replace my rear diff bushing last night because I had a fair amount of clunking - The bushing was pretty much just an oval core floating in the pressed in sleeve at this point so its good that im replacing it.
Im having a hell of a time getting the old sleeve out - didnt get the custom steel tool, but I tried using a puller of my own and i was afraid I was going to deform the aluminum ring it goes in. I think I can get it out tonight, but Im worried about putting the new one in.
Any hints for the install to make sure the thing goes in square? How much force does it take to get it in? Is it going to be a massive load required or is it a light press fit? Does greasing it up help any?
Thanks for any help - this is going to bug me all day at work.
Bacon is offline   Reply With Quote
Old 08-07-2012, 09:30 AM   #2
Use a hacksaw and very slowly cut through the sleeve, but not into the diff housing. That should allow you to remove the sleeve.
Which diff bushing are you replacing it with ?
rjoffe is online now   Reply With Quote
Old 08-07-2012, 09:42 AM   #3
soulja's Avatar
Yep, a hacksaw should do it. Just cut about a 1/4 inch piece out and you should then be able to pry the sleeve out with a flat head screwdriver.
soulja is offline   Reply With Quote
Old 08-07-2012, 09:50 AM   #4
ugh...dammit i knew that was going to be the answer. I spent an hour with a keyhole hacksaw last night doing just that. Its about ready to come out, but like I said Im worried about how the install will go. PLEASE tell me it goes in easier than it comes out?
Im replacing it with a CS bushing. Once this is done Ill post some pics and video - the old one was so bad that the internals fell out and I could move the differential about 1/2" with one hand. I bought it 2 weeks ago so apparently the previous owner learned to deal with it?
Old 08-07-2012, 10:10 AM   #5
You should have no issues with inserting the CS busing.
Old 08-07-2012, 10:18 AM   #6
BudRacing's Avatar
If anything stick it in the freezer for a couple of hours before installing. That should shrink the metal sleeve up some.
BudRacing is offline   Reply With Quote
Old 08-07-2012, 12:31 PM   #7
Anyone have any idea what the interference or press fit will be for this thing? I called CS and he said he thought it was .020"? That sounds huge to me, especially in thin cast aluminum. Wouldnt a press that tight just dig the aluminum out anyway thus reducing the amount of press?
Might have to try to heat the diff and cool the busing to get it to go in nicely...
Old 08-07-2012, 01:07 PM   #8
Sometimes when I kick problems like these around I'm embarrassed to say im an engineer.
So I ran some numbers and this may help people in the future:
coefficient of linear expansion for aluminum is 23x10^-6/C and 11x10^-6 for carbon steel.
If I can heat the aluminum of the diff by even 50*C, then I will have 23x10^-6/C * 50C * .048(diameter of bushing) = .055mm growth in diameter which is roughly .002".
Similarly with the bushing, if I can COOL it by lets say 35*C, then I have 11x10^-6/C * -35C * .048 = -.018mm shrink in diameter which is roughly .001".
So heating and cooling I can gain maybe .003" in my favor - thats not much when I need to get to the .020" they claimed. Looks like ill be borrowing a heat gun from work tonight.
Old 08-07-2012, 02:24 PM   #9
BudRacing's Avatar
I'd probably use a propane torch, but that's just me.
Old 08-07-2012, 02:28 PM   #10
Eh, gas tank near by, some residual penetrating oil...we'll see how daring I get. I may also just turn the sucker down a little in the shop. If it truly is a .020 press fit, you would have to heat the diff to 950 degrees Celsius in theory just to get the press fit down to a 1:1 fit. Since aluminum melts at 660C, I dont see that happening. AKA, I dont see need for such a tight fit.
Old 08-07-2012, 02:58 PM   #11
Fuzzy_Wuzzy's Avatar
other people have installed these before so i would assume the size is ok. You have the diff and the bushing so go measure and see how much of a press fit it really is. and convert to english units... for temp i have to think about celcius too much to get a feel for how much energy that is...
Fuzzy_Wuzzy is offline   Reply With Quote
Old 08-07-2012, 03:29 PM   #12
SSmokd U's Avatar
A freezer, hammer & block of wood is all you should need. You are over analyzing this big time. I rented the tool to do mine but if I had done a little more research I would have passed on the hassle of waiting then return shipping.
SSmokd U is offline   Reply With Quote
Old 08-07-2012, 03:36 PM   #13
soulja's Avatar
You are seriously over thinking this. I agree with SSMOKD U. Freeze it, then get a nice heavy blow or smaller sledge and a piece of 2x4 and knock it in. I recall it being very easy putting the frozen bushing in.
Old 08-07-2012, 03:37 PM   #14
lollygagger8's Avatar
Ya, use a hacksaw blade to get old sleeve out.
Here's my writeup on CF.....
Missing pics on page 7
http://www.cadillacforums.com/forums...l-removal.html
Like above, freeze the new bushing and hit with a small hammer. Don't over analyze it.
lollygagger8 is offline   Reply With Quote
Old 08-07-2012, 03:49 PM   #15
Ha, I read all those posts. That coupled with all the trouble to get the old one out is what makes me analyze this. Plus, Im putting in the CS instead of the UUC which seems to slip in much easier.
Im at work and have nothing to do other than overthink this...leave me alone Ill just squirt some KY Jelly on it - you can get a cadillac in a doghouse with that stuff.
Old 08-07-2012, 05:33 PM   #16
hmmmm
Old 08-08-2012, 01:49 AM   #17
SSmokd U's Avatar
BTW I did the CS bushing too. I have all of their bushings/mounts. FREEZE IT & BEAT IT! LOL
Old 08-08-2012, 09:11 AM   #18
I must have been tired the other night and gave up too soon. Came home after work yesterday and with one tap of the hammer i heard a loud TING, and then the old steel ring popped right out.
Before I left work I took .005 off the diameter of the new CS unit for the first .200 to give it a lead in. With a rubber mallet that first 200 seated like butter. Lubed the rest of it up and put the press on and it went in nicely on the first try. Getting a press fit started right is all it takes.
The whole reassembly took about an hour and was much easier. Left the exhaust on (lowered it from the hangers though), left the driveshaft in place. You dont need to take those out.
Heres what I pulled out - completely shot. The new bushing completely eliminated the clunk that I had and left me with a slight click. The holes in the mounting bracket are just a little bigger than the bolt so I think its the bolt moving around under load. There is a little more whine present now, but its much better than the clunk.
Old 08-08-2012, 12:33 PM   #19
BudRacing's Avatar
Yeah, whoever designed those original bushings failed miserably.
Old 08-08-2012, 01:41 PM   #20
Cadzilla's Avatar
Did that thing look like this in the housing?
I'm wondering if mine could be shot but look fine on the outside edge..
Cadzilla is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Noise AFTER bushings??? jkel1124 Cadillac CTS-V 2004-2007 (Gen I) 27 04-07-2015 12:25 PM
Poly Bushing Question JOHNNYMO Suspension & Brakes 17 09-20-2014 08:04 PM
Revshift bushing install suggestions mike6466 Cadillac CTS-V 2004-2007 (Gen I) 6 08-10-2014 12:37 AM
Creative Steel Trans Mount & Diff Bushing Installed :) KamaSutra Cadillac CTS-V 2004-2007 (Gen I) 9 10-21-2011 10:38 PM
Removing the Rear Control Arm Bushing Sleeve Counted Out Suspension & Brakes 13 06-14-2011 01:09 PM
Tags
06, 2006, 2007, bushing, bushings, cadillac, cts, ctsv, differential, ls1tech, mount, pinion, rear, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
