Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
High oil temps/fluctuation
Old 08-17-2012, 12:52 PM
Bacon's Avatar
Default High oil temps/fluctuation
Ive read the threads saying that the IPC or whatever can be reprogrammed to fix a glitch in the oil temp calculation, but would that fix fluctuations as well?
Yesterday I noticed the oil temp went up to 260 while in normal city driving - coolant was at 197. Today it sat at 220-230 the whole time even with some hard acceleration. Is it a bad ground issue or is it the IPC programming? No lights have gone off, but i dont like the gauge up there when I know the oil isnt really that hot.
Old 08-17-2012, 12:56 PM
BudRacing's Avatar
https://ls1tech.com/forums/cadillac-...0-degrees.html
Old 08-17-2012, 01:30 PM
Bacon's Avatar
Yup, read that. Guess i more focused on the fluctuations rather than a blatant offset. Ill check the grounds anyway.
Donde esta the oil temp sensor on a CTS-V?
Old 08-17-2012, 01:32 PM
heavymetals's Avatar
The fluctuations can be the result of your a/c or the radiator fans turning on and off.
Simple check is to turn off the a/c while looking at the oil temp.
If it moves, you got a funky ground.
Old 08-17-2012, 01:46 PM
BudRacing's Avatar
The oil temp sensor I believe is on the side of the oil pan.
Old 08-17-2012, 02:01 PM
Combo sensor.
It is also the oil level sensor.
Old 08-17-2012, 04:00 PM
Bacon's Avatar
AC was and has been off - must be a ground issue
Quick Reply: High oil temps/fluctuation
