Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
DIY Ford 8.8 into V1 Build thread
Old 10-15-2012, 11:22 AM
  #41
FuzzyLog1c's Avatar
Why are you guys buying Cobra (Ford Racing) differentials instead of Eaton True-Trac differentials?
If you plan on making more than 500 RWHP, isn't the extra $250 is worth it?
Old 10-15-2012, 11:58 AM
  #42
punishmentcycle's Avatar
the stock ford trac locks with carbon discs have seen 800+whp and have been just fine. anything can break with the right variables
Old 10-15-2012, 12:13 PM
  #43
RagunCajn's Avatar
Originally Posted by penn73
About 30 miles north of New Orleans
I must be in your backyard. I'm 10 miles from Hammond. We should go grab a beer and talk cars.
Old 10-15-2012, 01:52 PM
  #44
soulja's Avatar
They can handle the power and plus they are quiet (no clunking).
Old 10-15-2012, 02:23 PM
  #45
shadyLS6's Avatar
ford oem front bushings are garbage. get these.. i have them and they are great
http://www.summitracing.com/parts/PTP-6-1609/
part # SUM-E730311 diff breather cheap n easy
@punish, check Jmargo's thread he has high detail pic on how to modify the cover to fit the brackets
https://ls1tech.com/forums/cadillac-...ver-8-8-a.html
Old 10-15-2012, 07:56 PM
  #46
Bowtie70SS's Avatar
Okay those bushings should definitely go on the list. What would solid mounting the rear diff do I wonder?
Old 10-15-2012, 08:38 PM
  #47
penn73's Avatar
For sure, I'm in Madisonville. Are you in Robert?
Old 10-15-2012, 09:03 PM
  #48
I8URSVT's Avatar
dont know if its been mentioned or not, but the ford explorers have 31spline diffs and can be picked up for cheap at the junk yard (assuming you found an early IRS 8.8 that was 28spline but wanted 31 spline axles).
Old 10-15-2012, 09:28 PM
  #49
54inches's Avatar
Originally Posted by soulja
You would have paid less just buying a Cobra Diff. I paid only $800 for mines with 3.73 gearing put in it. Plus $100 for the CS Cover.
It was as small testimonial to show what others are doing, no need for a pissing contest. lol
Trade ya for a Gen 4...
lol Wish I had one myself!
One guy over at the other site solid mounted his with washers.
AGAIN, as I get info I am updating the first post. Check there first before you post.
Old 10-15-2012, 09:52 PM
  #50
jmargo's Avatar
Man, someone needs to tell that guy to clean his garage !
Old 10-15-2012, 10:29 PM
  #51
penn73's Avatar
I travel to Houston quite a bit for work so if you're still looking the next time I head that way we can hook up.
Old 10-16-2012, 09:38 AM
  #52
54inches's Avatar
Absolutely! Just looking for a broken, still intact housing, that I can use to make a jig to build new brackets around.
I have a few lines on a 8.8 cradle locally, so this should be really easy to replicate.
Old 10-16-2012, 10:13 AM
  #53
soulja's Avatar
Not trying to start a pissing contest. I am just saying why go through the hassle of sourcing all the parts, having the put it together, and in the end still pay more in time and money? Unless you like that kind of thing. Your world bro. Just sayin
Old 10-16-2012, 10:34 AM
  #54
i see where hes coming from but he is spending more money than its worth.. my 8.8 build cost around 450 plus the partial kit.. thats an old thunderbird iron housing $100.. explorer carrier $50, $35 carbon discs from a cobra.. powdercoating free for me, bearings and seals $100, gears $70 3.55's front ploy mounts $25..
im building and setting it up so it wont break or whine. to me thats priceless. seems like everytime i break something and rebuild it..that part is good but something else always breaks or goes bad :-(
  #55
Bowtie70SS's Avatar
I wonder if it possible to get the rear axles out of the Exploder and have the end resplined to fit the Cadillac outer joint? I will call Moser and see if they can do it.
In the pic of the mounting bracket above someone added a lot of extra bracing. I wonder at what point it would actually be needed? It looks strong as hell though.
EDIT: I called Moser and it is $75 per axle to respline the end plus $25 for a snap ring groove. Now I have to figure out if the Explorer or Mustang axle has the length and or the diameter needed to make this happen. I am sure the creative steel axles are worth the money but if you could do the conversion yourself for $1000 instead of $4500 that makes things more bearable. I could upgrade as needed at a later time.
Old 11-21-2012, 07:08 AM
  #56
AAIIIC's Avatar
I've been keeping my eye on Ebay for used 8.8" IRS diff housings, specifically the aluminum Cobra or Mark VIII ones. (Yes, I realize the Mark VIII is 28-spline, but I would be replacing the diff, anyway, so that doesn't matter to me.) Here's the search I've got saved - (cobra, mark, mk, viii) (diff, housing, carrier, differential, irs, center) -kit -toyota -supra -vw -jetta -skf. Obviously, if you don't care if you get aluminum or cast iron, then you can expand the "(cobra, mark, mk, viii)" to include "cougar, tbird, thunderbird,...". It doesn't appear that the cast iron ones are any cheaper, and I'd rather have the lighter aluminum for the same money.
The price range on the diffs is pretty amazing. I've seen used Mark VIII diffs as cheap as $125 (+ shipping, of course) and as high as $500 or $600 (for just the center section, not the entire rear end). The Cobra ones are generally more expensive. I was watching a Cobra one for only $150, but didn't ever actually put a bid in , and it didn't sell. I shot the seller a message asking if he was going to relist it and he responded with, "Nope, sold it to a buddy. He's going to put it in his CTS-V."
Old 11-21-2012, 08:30 AM
  #57
shadyLS6's Avatar
make sure you get a 03-04 Cobra pinion flange.
Old 11-21-2012, 08:58 AM
  #58
NIKDSC5's Avatar
76$ ford mark 8 alum diff housing. 450$ thru Trac 31 spline. 100 for rebuild kit and seals. 75 motive 3.73 ring and pinion. Total 726$ just for my own diff build.
Old 11-21-2012, 02:02 PM
  #59
Lbar's Avatar
3. The newer Cobra Mustangs, 99-04 have a 31 spline carrier.
The 99 Cobra's have a 28 Spline carrier. 01,03-04 had 31.
So if we get a 28 spline 8.8 we can use out stock cts-v 1/2 shafts?
Old 11-21-2012, 02:29 PM
  #60
chitown21y's Avatar
^^^This is the key question?
Quick Reply: DIY Ford 8.8 into V1 Build thread
