Rear Diff Bushing.
The diff does not need to be removed although it does make it easier. What tools are you using to remove and install the bushing?
Support the diff, remove the driveshaft from the diff, remove the 2-21mm bolts that go into the ears of the diff. They don't come all the way out. Then remove the bolt and nut that go through the rear diff bushing. you'll be able to lower the front the diff enough to get some room to work with to get the bushing out. Just be careful if you're using a chisel or airhammer when removing the bushing, I have seen the diff housing crack with a slip of an airhammer.
I found this video.
Sound like what you are talking about.
You need no special tool in order to reinstall the cv shafts.
If it was me I would try to cheat. Remove driveshaft and then put a jack under the diff. Remove all 3 bolts holding in the diff and then lower it with the cv's still installed. Might be able to get it low enough to change the bushings. If this fails then you are just going to have to do what you originally planned and remove the cv's to remove the diff. good luck!
Edit: or rotate the diff downward like that video! that seems it should work to me. as far as seals go you will have to remove the cv's or just add fluid and live with the leak!
If you're replacing a rear axle seal also then it wouldn't be a bad idea to just remove the whole rear end. You can disassemble the right side knuckle to remove the axle from the diff. They're all 21mm bolts, just mark which one goes where. You don't have to remove the axle nut, just make sure to disconnect the speed sensor. The whole knuckle and axle can be swung out and hang on the e-brake cable. That'll allow you to slide the diff towards the right and out of the car. While it's out I'd replace all the seals; two axle seals and pinion flange seal.
