Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Oil pressure high!
Old 02-02-2013, 07:47 PM
Bowtie70SS's Avatar
Default Oil pressure high!
I had the engine and transmission out of my car last week doing a heads and cam swap. I installed a new GM LS6 pump that I ported as well. I have driven it maybe 15-20 miles. Tonight I started it up and let it warm up for 15 minutes to melt the snow and ice off. After that I was sitting in the car revving it a little (not beyond 3500) when I look down and the oil pressure was a little high at like 60 at idle then I revved it again then 70 at idle, next time it was 90. I am really hoping its just a sending unit and from what I have read that is the most probable cause. Anyone else experience this?
Old 02-02-2013, 08:18 PM
NIKDSC5's Avatar
Not sure if high oil pressure is a problem? Did you put in a different spring in the pump which could have uped the pressure?
Old 02-02-2013, 08:27 PM
Bowtie70SS's Avatar
OK, I missed the obvious. Thanks RaDeon for filling me in.
Old 02-02-2013, 08:30 PM
Bowtie70SS's Avatar
90 psi at idle would be a problem if it were that high. The pan would be empty by 5k RPM. I ported a brand new LS6 GM pump and installed two small flat washer #10 shims which bumped the pressure maybe 10psi. I have been told the ported pumps can kill a sender. Oh well this info is out there now hopefully it helps someone. It is cool seeing over 100psi of oil pressure though. My 454 has about 80 cold.
Old 02-02-2013, 08:31 PM
NIKDSC5's Avatar
So...fill us in? Sender bad? Reading 38psi with the engine off I take it?
Old 02-02-2013, 08:35 PM
NIKDSC5's Avatar
My family runs a pulling tractor with a dry sump and it is at 100 psi at idle, 250 down the track. Yeah I know, different animal. It would def suck to suck the pan dry though.
So...side not if you're doing all this do ya have any #'s for us yet on the build?
Old 02-02-2013, 09:03 PM
Bowtie70SS's Avatar
I should have the injectors Wednesday. It has been cold and snowy here as well. I have the 102mm MAF to put on also. I have the preliminary tune ready to go . I am hoping for the end of next week to have it dyno tuned at Cincy Speed.
Old 02-02-2013, 09:13 PM
NIKDSC5's Avatar
Where did you get the MAF? Also price?
Old 02-02-2013, 09:49 PM
Bowtie70SS's Avatar
I guess it is essentially just a GM LS3 MAF. It is in a 102mm housing and called a PowrMAF was $199. http://www.powrmax.com/PowrMAF%20100.html They have all the tables posted on the site as well so you can plug them into the tuning program of your choice.
Quick Reply: Oil pressure high!
