Headlight ?'s!!!!
Headlight ?'s!!!!
I have a 05 CTS-V and somehow the drivers side headlight decided to crack the lens. It's just a small crack at the bottom center of the headlight about an inch long. I noticed it starting to get moisture on the inside of the headlight and now the low beam/hid bulb went out. Before I start trying to find out if it's the ballast or the bulb my question is this..
Has anyone put a set of aftermarket hids in the stock housings? I could buy 2 or 3 sets of aftermarket hid kits for the price of just a replacement bulb/ballast. Also if that's not a possibility has anyone changed out factory bulbs/ballast and noticed a different color from the replacement bulb/ballast vs the stock older bulb/ballast??
http://www.ddmtuning.com/Products/DDM-HID-Kit-D1SR-35W
ddmtuning is the way to go IMHO, I've had great luck with them. Also you can find stock replacements on e-bay for rather cheap if you search for a D1S bulb, the ballasts are a little tricky though. Sold mine for $50 each on e-bay a few months ago.
I ordered these off ebay for my 04 Sierra Denali truck and they are awesome, def gonna order them for my Caddy V. He even took my offer of 35. Been over a month now and no flickering or anything, hopefully they last. Light up the road great
http://www.ebay.com/itm/251187047772...84.m1439.l2649
55w 6000k
55w 6000k
DDM tuning hid kits are from my experience the best, bought two different kits before hearing about DDM kits and kept having ballast issues. Not one issue from them and they are cheaper than the other kits I bought at first.
Should have done my research with them first, I just assumed the there wasn't a kit for the car since it has the factory hids. Really which our kit was cheaper like all there other kits, but I guess it's the perks of owning a Cadillac!!
Anyone have a link for the double halo aftermarket headlights? I can save $100 and buy a regular hid kit from DDM for $35 vs the d1s bulb kit. Unless someone has a spare drivers side headlight.
I need to seal the crack on the headlight to prevent moisture from ruining my new lights and the only way I can think to do it is with some clear silicone, but that would most likely look crappy..
