Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Leaking water pump?
Old 08-15-2013, 12:24 PM
MichaelSuch's Avatar
Default Leaking water pump?
Hey guys,
I have a small coolant leak somewhere. I've checked the upper hose, its good. The lower hose is wet along with the timing cover. I can't really get in to check the water pump but I'm thinking it's leaking from there if the timing cover is wet. The lower radiator tank was leaking occasionally but it was not wet at all. Is there any where else it could be leaking from in the front of the engine but below the upper radiator hose? Looks like a new water pump from gmpartsdirect is $206. Is there any place known to be cheaper? Thank!
Old 08-15-2013, 02:08 PM
rwarden90's Avatar
i just got one for a z06c5 vette its was like 130.It has a thicker pulley but seemsto be working just fine pn 252-0846.
Old 08-15-2013, 02:20 PM
DACTARI's Avatar
I bought this stock replacement one from Amazon. 188.7:
ACDelco 89018052 Water Pump Assembly http://amzn.com/B000JZZ8EO
Quick Reply: Leaking water pump?
